Re: Oil pressure
As a rule of thumb for GM engines, oil pressure should be roughly 10 PSI/1000 RPM. Generally it will be between 25 and about 40 at idle (engine warm). Hot oil after a long WOT run may result in readings in the 10# range at idle but that's perfectly acceptable. Another rule of thumb is as long as you have "some" oil pressure at idle and normal pressure at cruise, you are still ok. I've seen engines run a good long time with very low idle oil pressure. It's a sign however, that the bottom end of the engine is getting a little used.
