Oil pressure
further
Further to my other post 😁, took the boat out for a water test today after a full tune up and oil change. I noticed the oil pressure gauge read higher than normal. Oil level reads perfect....put in about 5-1/2 quarts with the filter. Oil pressure is very high at WOT or around 4000rpm and fluctuated quite a bit. At neutral it’s at about 30-40. Is this normal? Guess it’s better than low oil pressure?
See video
https://youtu.be/wbOdncPQrvo
further
Never mind my post... after researching through older posts, I think I’m perfectly fine with the pressures I’m reading particularly with new oil.
All good 😁
