Oil prime 120hp 2.5l
Optimax89
Finally started working on my almarine with an 120hp 2.5l engine
the boat isnt used for 4-5 years
got the engine cranking but i dont get any oil at the valves, oilfilter or oil presure sensor
is there any way to prime the oil system before firing it up? ( like a v6 of v8 with a prime tool through the distributor hole )
thanks
marc
Ayuh,..... Welcome Aboard,...... Spark plugs in,.. or out,..??
Is the rotor turnin' in the distributor,..??
How long are you crankin' it on the starter,..??
Is the oil level at or near the full mark,..??
Optimax89
Sparkplugs out
rotor is turning ( but the previcious owner swapped the points distributor for a electrical, so he might have done somethin wrong )
oil level at max
ive cranked it aprox 2 minutes with short brakes after about 15seconds
does the engine rotates clockwise or counter when cranked?
fresh oil and filter?
pre-fill the oil filter?
Optimax89
Fresh oil and filter
and filter was prefilled but its side mounted so lost half of what went in
the valves will take a bit of time for the oil to get there. however you may need to crank for a while, or spin the oil pump with a drill
Optimax89
Is that the same “drill” tool as a v8? Or do in need to take my spare distributor apart and use that lower part?
would have to look. it may be a hex drive
