clerihew82
- Jul 10, 2007
- 57
I have a omc 3.0 stringer drive that i replaced some of the stringers and engine mounts. Since i had the engine out i thought i would do a little maintenance on it since it would be so easy to get to. First of all im changing the oil. How many quarts should it hold? Another question is the oil fill plug on the back of the engine. How much does it hold and should i need to change it and what kind of oil? 90w. I attached some pics to show you where im taking about. Also the tilt clutch housing. Do u also put 90w in there?
