OIL SHELF LIFE???
Boilermaker
Is there a shelf life on TCW3 oils??? I buy gals.of Penzoil Synthetic at Wmart when I visit my folks. Their isn't a Wmart near me & I want to stock up when I go>>>I would like to buy enough now for the upcoming season, or MORE. ANY PROBLEM???
petrolhead
Re: OIL SHELF LIFE???
Interesting question, mineral oil has been underground for millions of years, so you'd expect it to have quite a long shelf life once bottled wouldn't you? I wonder how that applies to synthetic though?
rodbolt
shake it well before using. I have seen some of the additives settle out after prolonged storage.<br /> good luck and keep posting
WillyBWright
Oil is about the only thing you can buy anymore with a longer shelf-life than a Twinkie. ;)
gss036
I bought a 55 gal drum of EXXON TCW years ago, it took me like 3 years to use it up and the only problem I had was that it started to jell up so I had to make sure I shook it real good. After that experience I went back to just buying gallons. It is much cheaper (50%) by the barrell. That is why the dealers can sell it in the bulk for a couple dollars less and still make a decent profit margin.
LubeDude
Originally posted by WillyBWright:<br /> Oil is about the only thing you can buy anymore with a longer shelf-life than a Twinkie. ;)
Youre killing me Willy, but its true. :D :D :D
dajohnson53
Is it really true that there is stuff in TCW3 oil that will settle out and that it should be shaken? What does that stuff look like? What is it? How long does it take to settle out?<br /><br />I've just never seen it, but then again I haven't even thought of it, haven't looked for it (or noticed it) and have never shaken oil containers.
JB
The oil will last longer than the shelf.
BoatBuoy
gss036,<br /> Shaking a 55 gal. drum of oil equates to the events in World's Strongest Man contest. Quite an accomplishment.
rodbolt
its like riplys. believe it or not. I have seen it. looks like mud at the bottom of the jug.
gss036
It was difficult, but you have to consider there was only about 10 gal by that time.:-} Then all you had to do was roll it around a little, you know what I mean??? I have friends who like to kint pick also :-}
macojoe
What is the difference, and can you still use it in something as new as a 1980 outboard.<br /><br />TCW & TCW 3 I have had a friend that gave me two 24 Quart cases of Johnson 50:1 outboard oil TCW But there is no 3 on it??<br /><br />Thanks
Twidget
My Dad (worlds origional cheapskate) bought a case of outboard oil from a Dollar store. When he opened it, the stuff had the consistency of motor honey, no amount a shaking/stirring made a difference.
WillyBWright
TCW is the first in the series. Then came TCW-2. Then they added a bit more anti-carboning agents and now it's TCW-3. The TCW should work fine. Before TCW there was BIA Certified. BIA went away and that's when TCW came out. Might just be a different name for the same stuff.<br /><br />Dollar Store outboard oil? I've seen some incredible deals at Dollar Stores, but I don't think I'd trust that one.
tfbrown1270
Hey!....this brings up an interesting thought....a friend of mine has been mixing shell 10w30 regular old motor oil in with his gas at a 50/1 ratio for decades....refuses to believe that we need tcw3 or any special two stroke oil at all....I know his engines have lasted and lasted....he even bought a new(er) Johnson 15 hp that he runs the same stuff in....is he crazy?...is he ruining his motors/ .... or is he just smarter than the rest of us!? :><br /><br />Tim
rabidfish
Some engines run Merc premium TCW-3 The larger ones should have Premiums PLUS TCW-3. Is it worth saving 2 bucks? I'd have to think about that one... no i wouldn't!
Scaaty
Originally posted by kenora:<br /> a friend of mine has been mixing shell 10w30 regular old motor oil in with his gas at a 50/1 ratio for decades....refuses to believe that we need tcw3 or any special two stroke oil at all<br />is he crazy?...<br />Tim
Probably.......!
dajohnson53
Originally posted by kenora:<br /> Hey!....this brings up an interesting thought....a friend of mine has been mixing shell 10w30 regular old motor oil in with his gas at a 50/1 ratio for decades....refuses to believe that we need tcw3 or any special two stroke oil at all....I know his engines have lasted and lasted....he even bought a new(er) Johnson 15 hp that he runs the same stuff in....is he crazy?...is he ruining his motors/ .... or is he just smarter than the rest of us!? :><br /><br />If by "smarter" it means he thinks he's actually saving money by using 10w30, I can't believe it's a meaningful savings from cheap Wally World gallon jugs of TCW3 oil. Unless he's using the absolutely cheapest 10w30 and is saving 75 cents a quart. He's probably not crazy, but seems kind of stupid, penny wise and pound foolish.<br /><br />Tim
