Re: Oil Tank Question
why did you remove the oil tank??? the rotary valve needs oil even if you removed the oil pump, you can use an automotive cooling system flush fitting between the 2 big hoses and fill them with oil for the rotary valve, using the cap to add oil when needed, as for the oil light jump the 2 wires that feed the sending unit, when you jump them together the light will go off, if you don't fix the oil supply to the rotary valve issue you will burn up the berrings on the rotary shafy.
