I have a 1999 250 saltwater series that the alarm keeps sounding on the oil sensors. I have tested the sensor in the tank on the motor, which appears to be good. The oil does not appear to be transferring from the remote tank to the motor tank. The oil pump on the remote tank test as good, the emergency switch test as being good but will not transfer oil from the remote tank to the oil tank on motor. I have not found a test to run on the sensor in the remote tank. Anyone have any suggestions or performance test I can try before replacing the CDI. Any wiring details suggestions on this?
