Oil Temp & Water Temp gauges read nothing when running!!
Dgavin9
I have a 1988 Bayliner Capri with I/O 5.0L 305 OMC out drive. This is my first ever boat and I have spent a lot of time rebuilding this boat. Out of all the problems I had, I only have a few left. This includes the oil temp and water temp gauges not working. They read nothing when the boat is running. I have no idea as to what the problem is as I'm new to boats and motors. I have been told it could be a bad gauge, bad sensor/sender, bad oil pump. I have no idea where to start to diagnose these issues. Any help is greatly appreciated. Thank you for your time
toddschubert
Power and ground to the gauge is where I would start. Do they flutter or budge at all when ignition turned on or motor started?
Dgavin9
I used a 12v tester. Used the ground on the gauges and the both have 12v. Any other suggestions?
Ayuh,..... If you ground out the sender wire terminal, the gauges should Peg, Full/ High, whatever,....
Dgavin9
Ahhhh I didn't know that. Shich means the gauge itself is bad? I ordered new guages from eBay a couple days ago. Just to test them and hope they work
Jammer864
Might check the umbilical plug and make sure its seated correctly in its receptacle. Im talking about a large 1 and 1/2 inch plug with several pins in it that connects to the engine. Wiggle that and see if your gauges move.
