OIL TEMPERATURE
Patrick_L
Is it normal for oil temp to go high when speeding at 75-100% capacity ?
( It is normal when just cruising )
Merc 4.3lx
alldodge
Merc 4.3lx
What do you mean by high?
It will be higher then the temps of the motor
alldodge
The oil gauge tips towards hot/high when going at full throttle
If gauge is accurate then its getting to hot (probably more then 240 degrees) but need to find out if the gauge is reading correctly. Can you get an IR gun and measure the temps at the oil filter?
Ayuh,.... The harder ya beat a motor, the hotter they run,....
So, Ya, pretty normal,...
If ya don't get the oil to 212?, the condensation don't steam off,...
Alumarine
Are you sure it's not oil pressure you're looking at?
If so, it will go higher at higher rpm's.
achris
More fish than mountain goat
I wonder if he's looking the 'Oil Pressure' gauge and seeing a 'Temperature' gauge next to it and thinking it's an 'Oil Temperature' gauge?
If that's the case, then the engine COOLANT temperature is getting too high. You have an engine COOLING problem.
Chris
achris
Yep !! It is the psi gauge and not the temp -_- so my guess is it is normal lol
OIl pressure going up as the engine runs faster? Gee, new invention. :D... Sorry patrick, couldn't help myself... All good... ;)
Cheers,
Chris....
Patrick_L
Me too Chris. I am new to boating and for some reason i thought this was oil / engine temp. My actual engine temp gauge thats nect to it is stuck so i dont even get the proper readout -_-
Thanks guys.
bruceb58
Thanks guys.
That's a very important gauge. You need to fix that.
