oil type advice
imported_alex_G
Hello all,
I have OMC 1985 5L.
My owner manual says to use OMC Hi-Vis Gearcase Lube however I don't have any OMC dealers close by. What oil can I use instead?
Thanks
Alex
Re: oil type advice
Well,..........
You Could fill it up with a standard EP 80W-90,.... As so known as Rear-End Grease.........
Or,..... You could go buy some of the same oil in a plastic bottle that says Marine on it,... For Twice the Money..........
Or,......... What I use,......
Mobil 1, 75W-90,.... Ful-Syn gear oil........
Any of the Off the Shelf Gear Lubes in a 90W or so will Work,...
Just Fine...............
Gary H NC
Re: oil type advice
CRC high vis gear lube is supposed to be the direct replacement for OMC...Sold at Napa, they had to order mine..
But like Bondo says..Mobile 1 is good too..
