Re: Oils
You can use the Automotive oil in a pinch if you have trouble getting marine oil, A synthetic would offer the best protection, and they are fine most anytime for a lower unit, but if you have to use automotive gear oil, I would suggest not running it for long trips and changing it out a minmum of two to three times a season if you use your boat a lot, and after its filled, let about an OZ, of lube drain out before you put the plug in, this allows for expansion because the oil will foam some. The automotive gear lubes do not have the anti foaming and water separating qualities you desire in a lower unit oil. Also if you use an automotive oil, it would be a good Idea to open the drain plug when you get the boat out of the water and actually check to see how much foaming you do get. If it is realy foamy, dont use that oil anymore. It would take at least an hour or more for all the bubbles to rise out of the oil.
