Ok, got her purrin! Now is this a rooster tail?
peacekeeper6
Ok, got the 200 bolted up...WORKED AWSOME. I have some fine tuning to do. As i didnt adjust the shift cable just right and it kinda sticks into reverse sometimes. But i have that under control. Also have a fuel leak going to trouble shoot that down, and i think that might be the cause of my problem that i have. Ok when shes warm she kind of puffs, and sputters, sometimes dieing sometimes not. Has very strong spark and rebuilt carbs last week. SO...i am thinking that my little fuel hose leak which is coming right where the main line comes into the pump, is causing not enough fuel pressure, or is somehow cuasing bubbles or whatever in the fuel lines, causing it to puff and sputter sometimes at idle, and sometimes i feel a noticable decrease in RPM at WOT. SO....am i onto something? I mean the mtor hasnt been run in about 3-4 months. SO, should i fix the problem and run a tank a two through it to see if that helps? I am going to fix the fuel problem either way i just want to know if i should look for something else. I whole heartadly appreciate all the guurus that help on these boards. If i could donate i would. after the corps i plan on going to MMI or Wyotech, i love this crap!
HighTrim
Re: first run on new engine setup, some advice please!
The fuel leak is a definate problem, double check the inner diameter of the line and replace it. Did you set your idle while on the water, it will be different than on the muffs. ALso get rid of that old fuel. Good luck.
peacekeeper6
ok thanx for the tips, didnt set the idle in the water will try that. i dont think its the line i think its the fitting that actually goes into the fuel pump. I got rid of the old fuel already was using a portable can for these tests thanx fellas.
HighTrim
set it to 650 under load in gear.
peacekeeper6
so would that leaky connection cause the lean condition that i beleive i am experiencing. I mean i am pretty dead set on that as the culprit (the lean condition) because everything i have read points to that.
ezeke
Any source of unwanted air in the fuel side can cause the engine to run lean with potentially very high damage to the engine. The high levels of heat generated because of the extra oxygen can actually melt and throw off particles of metal from the pistons.
peacekeeper6
that sux bad, i will fix asap, also i forgot to mentiont that the cough is sometimes heard as a i guess gasp of air through the carbs. are we all thinking lean?
peacekeeper6
ok, quick questions....is this a rooster tail? My 25" shaft is 2" below the bottom part of my transom.
