OK, Info you need to give me Info I need
Hondo65
Today I got the boat out for the second time in my ownership. Forst time on nearly glass smooth Conesus Lake. Here are the results. I would like to know what I would gain by going to a 14.5x19 prop. The 14.5x17 is a little chewed up also, the 19 is like new though I need to put in a new Flo-Torq II Hub.
14.5x17Pitch, 4800 -5000 RPM 43-45 MPH (GPS) depending on trim and direction.
Will the 19 bring me down into the recomended 4600-4800 and give me a little better top end?
Currently she gets up on plane FAST. will cruise at about 21mph on plane.
Any info and insite will be appreciated.
Thanks
Hondo
steelespike
Re: OK, Info you need to give me Info I need
I would think the 19 would give you about 4,600 rpm little slower hole shot.
Wouldn't hurt to get your 17 fixed and see what you get.keep it for a spare or for skiing or sell it.
Hondo65
Thanks that is what I am looking for. Hole shot right now is awful good. I don't think the 19 will hurt it too much. I would like a little more top end. No one will be skiing behind this boat. Tubing maybe
Hondo
mpsyamaha
19 will be good for your purpose
Ayuh,......
The 19" should put you Right in the Sweet Spot for that 350,......
I Don't think you'll loose anything noticeable on the bottom end,+ will probably pick up some top end,.....
But,....
I'm guessing you'll still be just short of 50mph.......
Hondo65
Thanks guys that is what I was thinking. But Bond-o I'll bet you I can get it up to 52mph...downhill;{]
Hondo
