MTboatguy
- Jul 8, 2010
- 8,988
Well, the dread of all dreads happened today and I am a noob on well water systems. We had a new water pump, plumping and well control box put in in 2003, I get home today, the wife says, we ain't got no water. I have checked all of the power connections, they are all tight, this system has a submerged pump at 490 feet, a small control box with a capacitor and relay and a two fuse switch box, I have power coming off the breaker box in the house, I have 240 volts at the fused switch box, where the wires split and one side goes directly into the pressure switch, that leg has 240 volts, and one side goes through the control box which I have no power coming out of, that goes to the pressure switch, what would you check first, the capacitor or the relay?
I know there has to be someone that has a similar system out there!
