ok to use newer coils on 79 evinrude 140?
fishdog4449
I have a 79 evinrude 140 with the dual power pack type ignition system, I Was wondering if I could use the newer (90s) style ignition coils, I haven't been able to find the exact ones that are on the motor. I've tested the newer ones and they read the same across all points, I believe they are from an 200 ocean runner. I don't want to damage the power packs but I don't see any difference in these newer style coils other than the casing and how the wires are attached?
Thanks in advance,
MJK
DargelJohn
Re: ok to use newer coils on 79 evinrude 140?
Here is a cross reference for your motor's ignition coil:
This Evinrude / Johnson 0581998 COIL ASSY. part is also used on these models and components:
EVINRUDE 1979 100990S 1979 IGNITION SYSTEM
EVINRUDE 1979 100993S 1979 IGNITION SYSTEM
EVINRUDE 1979 100999S 1979 IGNITION SYSTEM
EVINRUDE 1979 10924B 1979 MAGNETO
EVINRUDE 1979 10925B 1979 MAGNETO
EVINRUDE 1979 10935B 1979 MAGNETO
EVINRUDE 1979 10955B 1979 MAGNETO
EVINRUDE 1979 115990R 1979 IGNITION SYSTEM
EVINRUDE 1979 115993R 1979 IGNITION SYSTEM
EVINRUDE 1979 115999R 1979 IGNITION SYSTEM
EVINRUDE 1979 140940R 1979 IGNITION SYSTEM
EVINRUDE 1979 140943R 1979 IGNITION SYSTEM
EVINRUDE 1979 140983R 1979 IGNITION SYSTEM
EVINRUDE 1979 150940C 1979 IGNITION SYSTEM
EVINRUDE 1979 150949C 1979 IGNITION SYSTEM
EVINRUDE 1979 15904E 1979 MAGNETO
EVINRUDE 1979 15905E 1979 MAGNETO
EVINRUDE 1979 15954E 1979 MAGNETO
EVINRUDE 1979 15955E 1979 MAGNETO
EVINRUDE 1979 175940R 1979 IGNITION SYSTEM
EVINRUDE 1979 175949R 1979 IGNITION SYSTEM
EVINRUDE 1979 200490A 1979 IGNITION SYSTEM
EVINRUDE 1979 200940A 1979 IGNITION SYSTEM
EVINRUDE 1979 200949A 1979 IGNITION SYSTEM
EVINRUDE 1979 235940A 1979 IGNITION SYSTEM
EVINRUDE 1979 235949A 1979 IGNITION SYSTEM
EVINRUDE 1979 70973R 1979 IGNITION SYSTEM
EVINRUDE 1979 75942R 1979 IGNITION SYSTEM
EVINRUDE 1979 75943R 1979 IGNITION SYSTEM
EVINRUDE 1979 85990R 1979 IGNITION SYSTEM
EVINRUDE 1979 85995R 1979 IGNITION SYSTEM
EVINRUDE 1979 85999R 1979 IGNITION SYSTEM
EVINRUDE 1980 E10ECSE 1980 MAGNETO
EVINRUDE 1980 E10ELCSE 1980 MAGNETO
EVINRUDE 1980 E10RCSE 1980 MAGNETO
EVINRUDE 1980 E10RLCSE 1980 MAGNETO
EVINRUDE 1980 E10SELCSE 1980 MAGNETO
EVINRUDE 1980 E15ECSD 1980 MAGNETO
EVINRUDE 1980 E15ELCSD 1980 MAGNETO
EVINRUDE 1980 E15RCSD 1980 MAGNETO
EVINRUDE 1980 E15RLCSD 1980 MAGNETO
EVINRUDE 1980 E70ELCSA 1980 IGNITION SYSTEM
EVINRUDE 1980 E75ERCSA 1980 IGNITION SYSTEM
EVINRUDE 1980 E75ERLCSA 1980 IGNITION SYSTEM
EVINRUDE 1980 E75TRLCSA 1980 IGNITION SYSTEM
EVINRUDE 1981 E70ELCIH 1981 IGNITION SYSTEM
EVINRUDE 1981 E70ELCIM 1981 IGNITION SYSTEM
EVINRUDE 1981 E70TLCIM 1981 IGNITION SYSTEM
EVINRUDE 1981 E75ERCIH 1981 IGNITION SYSTEM
EVINRUDE 1981 E75ERCIM 1981 IGNITION SYSTEM
EVINRUDE 1981 E75ERLCIH 1981 IGNITION SYSTEM
EVINRUDE 1981 E75ERLCIM 1981 IGNITION SYSTEM
EVINRUDE 1981 E75TRLCIH 1981 IGNITION SYSTEM
EVINRUDE 1981 E75TRLCIM 1981 IGNITION SYSTEM
JOHNSON 1979 100ML79S 1979 IGNITION SYSTEM
JOHNSON 1979 100TLR79S 1979 IGNITION SYSTEM
JOHNSON 1979 100TXLR79S 1979 IGNITION SYSTEM
JOHNSON 1979 10EL79B 1979 MAGNETO
JOHNSON 1979 10R79B 1979 MAGNETO
JOHNSON 1979 10RL79B 1979 MAGNETO
JOHNSON 1979 10SEL79B 1979 MAGNETO
JOHNSON 1979 115ML79R 1979 IGNITION SYSTEM
JOHNSON 1979 115TL79R 1979 IGNITION SYSTEM
JOHNSON 1979 115TXL79R 1979 IGNITION SYSTEM
JOHNSON 1979 140ML79R 1979 IGNITION SYSTEM
JOHNSON 1979 140TL79R 1979 IGNITION SYSTEM
JOHNSON 1979 140TXL79R 1979 IGNITION SYSTEM
JOHNSON 1979 150TL79C 1979 IGNITION SYSTEM
JOHNSON 1979 150TXL79C 1979 IGNITION SYSTEM
JOHNSON 1979 15E79E 1979 MAGNETO
JOHNSON 1979 15EL79E 1979 MAGNETO
JOHNSON 1979 15R79E 1979 MAGNETO
JOHNSON 1979 15RL79E 1979 MAGNETO
JOHNSON 1979 175TL79R 1979 IGNITION SYSTEM
JOHNSON 1979 175TXL79R 1979 IGNITION SYSTEM
JOHNSON 1979 200TL79A 1979 IGNITION SYSTEM
JOHNSON 1979 200TXL79A 1979 IGNITION SYSTEM
JOHNSON 1979 235TL70A 1979 IGNITION SYSTEM
JOHNSON 1979 235TXL79A 1979 IGNITION SYSTEM
JOHNSON 1979 70EL79R 1979 IGNITION SYSTEM
JOHNSON 1979 75ELR79R 1979 IGNITION SYSTEM
JOHNSON 1979 75ER79R 1979 IGNITION SYSTEM
JOHNSON 1979 85ML79R 1979 IGNITION SYSTEM
JOHNSON 1979 85TL79R 1979 IGNITION SYSTEM
JOHNSON 1979 85TXL79R 1979 IGNITION SYSTEM
JOHNSON 1980 J10ECSE 1980 MAGNETO
JOHNSON 1980 J10ELCSE 1980 MAGNETO
JOHNSON 1980 J10RCSE 1980 MAGNETO
JOHNSON 1980 J10RLCSE 1980 MAGNETO
JOHNSON 1980 J10SELCSE 1980 MAGNETO
JOHNSON 1980 J15ECSD 1980 MAGNETO
JOHNSON 1980 J15ELCSD 1980 MAGNETO
JOHNSON 1980 J15RCSD 1980 MAGNETO
JOHNSON 1980 J15RLCSD 1980 MAGNETO
JOHNSON 1980 J70ELCSA 1980 IGNITION SYSTEM
JOHNSON 1980 J75ERCSA 1980 IGNITION SYSTEM
JOHNSON 1980 J75ERLCSA 1980 IGNITION SYSTEM
JOHNSON 1980 J75TRLCSA 1980 IGNITION SYSTEM
JOHNSON 1981 J70ELCIH 1981 IGNITION SYSTEM
JOHNSON 1981 J70ELCIM 1981 IGNITION SYSTEM
JOHNSON 1981 J70TLCIM 1981 IGNITION SYSTEM
JOHNSON 1981 J75ERCIH 1981 IGNITION SYSTEM
JOHNSON 1981 J75ERCIM 1981 IGNITION SYSTEM
JOHNSON 1981 J75ERLCIH 1981 IGNITION SYSTEM
JOHNSON 1981 J75ERLCIM 1981 IGNITION SYSTEM
JOHNSON 1981 J75TELCIM 1981 IGNITION SYSTEM
JOHNSON 1981 J75TRLCIH 1981 IGNITION SYSTEM
