punkyBOATER
- Jun 2, 2004
- 24
Okay, first of all id like to start out by saying i know i shouldnt of done what im about to explain i did. I have an 85 Bayliner equipt with a 125 force motor. I had to drop my lower unit to replace the water pump and impeller due to overheating. I had a u know what of a time getting it back up by myself. In the process i think i might of bent the shift rod and i unscrewed it thinking i could guide it through its hole as to get the lower unit to line up and go together. After i got the lower unit back up I tryed to re-adjust the shift linkage with the motor off by having someone put the shifter at the helm back and fourth until it felt like neutral was neutral. In doing this i noticed that the shift rod was rubbing against one side of the opening and i thought to myself i probably bent it while trying to line up the two half's, and that it could either make shifting a little ruff or maybe even hose stuff up. I went out to the lake today and launched without problems had reverse and forwards. I then entered a cove and threw the boat into reverse only to find it wasnt there. The motor just rev'ed like it was in neutral and i thought huh this isnt good. So we immediatly beached the boat and decided to have our fun in the sun and not drive the boat until it was time to head in. Well the time to head in came and i had a good time getting the boat off the beach without reverse and found out i am a very strong swimmer and can tow a 19" bayliner about 25 yards and climb back in and fire it up before we blew back into the beach =). Well you can prob guess what happened next, yup thats right boat did not move just rev'ed like it was in neutral. So now i dont have reverse or forwards. I thought it might be the shift assy at the helm and took it apart because it was already loose and i thought it might be the culprit, but it seemed to be operating okay. The Lake was closing and i didnt have sufficent tools so we got towed back in and now im a bit dissappointed in myself, there is one good side to what happened today...I DIDNT OVERHEAT =) a new water pump unit and thermostat fixed that....i also added 1/2 a can of power tuner and am running a few mph faster =). If anyone has incountered this and has some advice id appreciate it. This is my first outboard boat motor expierience and i need all the help i can get. Thanks in advance and sorry for the length of the post but i just wanted to make sure i covered everything. P.S. is there anything you can do besides adjust the skag to compensate for the pull to the left under heavy throttle? Thanks again.
