Late 70's merc 90hp w/ elec ignition hard starting, backfiring and backwards run then die's . Crank and distrubitor keys checked, new timing belt, Dist Cap, Starter and plugs,Wires check out ok, float level ok good fuel pressure. Ran fine one day the next day this was our problem any idea's??? This motor was installed into a different boat and the Tach is also not working. Has anyone had problems with elec remote controls associated with this motor and could they cause the problem? <br />--------------------------------------------------------------------------------
