Re: OLD 18 H JOHN PLEASE TELL ME SOMTHING ABOUT HIM
Paul, great article, thanks for posting that up...
Rob, your motor is a battle wagon. I have one of these and they're die hards. I have run this motor at WOT for 3 hours with nary a hic-cup. Heck, I have a 1 year old outboard that requires more attention!
Parts are readily available, and the prices are very reasonable. My preference is to stick with genuine OMC parts when available.
Post up the model #, and you'll be able to get absolutely TONS more info on it. Next order of business is to get a service manual. Clymer or Seloc is a good start. If you want the real service manual, go to kencook.com
First service related thing I would do though, is run a compression check. Pull the plugs, throw her into drive, go into wide open throttle, and crank the engine for about 3-4 seconds. If you don't have the starter feature, you'll need to pull that rope 2-3 times. Mine is 118/top - 116/bottom. This will give you a good reference as to what the numbers should be like.
You need that tank - you can get 'em off ebay for a reasonable price. Two different tanks are available, one has a plastic primer knob, and the older ones have the metal ones. Either will work, but if you need a rebuild kit, they're different.
Do an ebay search like "vintage outboard tank" - quite a few come up.
Parts lists and owners manuals can be had at ebay as well. If yours happens to be a 1959 (model FD13), I have parts lists and owner manuals. Email me at
chevydriver37@yahoo.com, and I'll be happy to send you a copy.
And like tashadaddy says, I wouldn't bother throwing a fuel pump on there. These are good systems when properly maintained.
Good luck!
Rick
