old aluminum boat needs new transom. How???
papason3
the short- what is holding the screws in and how to i reattach when i get another transom built? Also not too important now but it had a bunch of things attached to it. Like handles Eyelets, hooks. How do i know what has to be back on there?
This boat i believe is a 196(0) something? maybe 18 feet long give or take some feet. I have not searched for what it is but seems like they said it was a crestliner. I got this from in-laws and they have passed on.
so it has a 40 horse Johnson outboard and the transom (plywood) warped and rotted. getting it off was a chore some is intact so can use as template. I cut a couple screws/bolts and several others just snapped, then i thought to cut around the rest. So now i have bolts and screws sticking out that wont come out and there is no access to inside. I am guessing there is a nut on the inside or what??
Thats it, what is holding them in and how to I reattach when i get another transom built? Also not too important now but it had a bunch of things attached to it. Like handles Eyelets, hooks. How do i know what has to be back on there?/
Baylinerchuck
Pictures speak a thousand words. Really hard to picture what you’re dealing with there. If you have a title or registration, (which you’ll eventually need), it should have the make and model listed there.
MOD EDIT - No, leave it here. The Tinny guys will see it.
papason3
Thank you.
still trying to get. A picture up, it is not working
The boat is a 1967 Crestliner on little dude trailer.
I will keep trying on the pictures, that is something I need to learn on this forum I am guessing as well as how to find your post easily.
GA_Boater
To find your thread or any posts you've made - Click on your Username on the top right, then click the Activity tab.
For help with pictures, click on Forum Help in the sig below and look at the Photo Tutorial.
And seeing I have no manners - :welcome: aboard.
papason3
G A-Boater
Thanks for the welcome i hope i have smooth sailing.
Anxious to learn about boats and restore this one and teach the kids waterskiing.
it looks like the boat had been modified from a shallow transom and splashwell.
papason3
So nobody has an idiea how these bolts are attatched or how to attatch a new transom?
sphelps
Post some pick of looking down from the top of the transom . It might give a better idea on removing the bolts . Should be able to just cut them out with an angle grinder or sawzall .
papason3
my concern is not getting them out but how to use them or how to attatch a new transom
