Old Bayliner with leak in gas tank
riverrat1961
Attempting to remove the tank. Tank is stuck in the hull and can not figure how to get it out. Any suggestions would be appreciated. This boat is a 1979 Santiago by Bayliner. Please no comments about my old boat. Had to start somewhere.
jigngrub
Re: Old Bayliner with leak in gas tank
If the tank is foamed in with expanding foam you will have to cut the foam to remove the tank... pictures will always help us to help you better.
Bob_VT
You can use a piece of wire and with maybe 2 people hook the wire under the tank and pull the wire across to cut the foam. It also depends on how it "might" be tied into the hull.
Okay..... no "old comments" :) However, it is nice that you are keeping it alive!!
