After you pull up your carpet, how do you remove the old, hardened glue that sticks to the hull? TG
C croSSed Petty Officer 1st Class Joined Jun 13, 2005 Messages 249 Dec 31, 2006 #1 After you pull up your carpet, how do you remove the old, hardened glue that sticks to the hull? TG
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,137 Dec 31, 2006 #2 Re: Old carpet glue A 4,1/2" Grinder with a Cup Wirebrush mounted on it,......... It Peels the stuff Right Off........
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Jan 1, 2007 #3 Re: Old carpet glue and safety glasses, mask, shop vac. and real old clothes. change in the garage before going into the house if you know whats good for you.
D dadgummit Petty Officer 3rd Class Joined Dec 30, 2006 Messages 96 Jan 1, 2007 #4 Re: Old carpet glue I used about a 4" razor blade scraper from the flooring dept. at your local home improvement store. Works good just be careful not to gouge the surface.
I imported_MattG Seaman Joined Nov 1, 2006 Messages 58 Jan 1, 2007 #5 Re: Old carpet glue the PO used Liquid nails to hold down the old carpet. I was thinking of using the scraper like dadgum said
