Old fiberglass hull foam
sqdqo
In an older Grady (1978) they used polyurethane in the hull. Would this foam have been a closed or open cell type? I am wondering if a person should be concerned about purchasing a boat this old and possible water logged foam or other unseen deterioration. Structurally the hull and deck seem solid.
tashasdaddy
Re: Old fiberglass hull foam
yes, you should be concerned, especially a boat that age.
qaztwo
'78 thats not old, got a '76 searay. The foam was completely saturated. Any wood that was in contact with the foam turned to mush.
Ayuh,......
The Foam used at the factory is the same foam used in rebuilds,.....
Closed Cell foam......
But,.....
With Time,+ Water,........ ALL of it becomes a Sponge.............
sqdqo
Will a surveyor uncover wet foam or rotten stringers?
tashasdaddy
if he is worth his money he should, or atleast the signs of it. you have to drill a hole in the deck to verify.
njlarry
Your other option is to weight the hull. Saturated foam will add hundreds of pounds. Could also drill hole at low point on outside of hull.
