old fiberglass
jelli
i have a old fiberglass boat that takes on water iv fixed all the leaks that drop water after i take it out of lake but it still takes on water any ideas
thanx
cr2k
Re: old fiberglass
NEI (the opposite of TMI) Not Enough Information. Engine? Drive? IO or OB?
Are you able to look at the hull where it sit on the bunks? I had a leak I could not find until I pulled the boat back a ways on the trailer and exposed a hole made by a loose bunk bolt.
Bob_VT
Re: old fiberglass
Check the seal from the rub-rail....... water splashes up and penetrates under the rub rail joint........often overlooked
