old fuel tank
zach103
i got a old built in tank. i want to restore it so i can use it agian. how do i clean the inside of it ??
Thanks
zach103
Re: old fuel tank
i looked inside the tank. it looks perfect except some paint chips fell in when i undid the latch. how can i get those out? should i just put a fuel filter on the hose and fill the tank up?
jeeperman
Re: old fuel tank
if you can see the paint chips you can retrieve them.
Use a wooded stick or something with a wad of plumbers putty on the end and stick'em up with the stick.
zach103
Re: old fuel tank
ill try that. what about the ones that i cant reach
zach103
Re: old fuel tank
yeh but they just fell in. its not stuck to the tank. im not sure but don't you use the bb's if their stuck to the sides? i removed the gasket and they fell in
Coors
Re: old fuel tank
The solvent and bb's scour the inside of the tank. If you have a trunk, do that and drive around for one week, hitting every pot hole/bump you can.
Re: old fuel tank
what about the ones that i cant reach. should i just put a fuel filter on the hose and fill the tank up?
Ayuh,.....
You should Always Filter your Fuel,..... A Water Seperating 1 is Best......
Coors
Re: old fuel tank
The bb's rattle around in the tank, and knock off the crud. Out of the boat.
