Old Gas
Deenniiss
I had some left over gas that has oil in it. Its 24/1 ratio. Would it hurt my car if I used it up in there? Will it be ok to use up in a few weeks if I go fishing again ? Its about 10 weeks old now.
12Footer
Re: Old Gas
If your car has a catalytic converter,it will also have an O-2 sensor. The oil in the mix will ruin them.Also, it can clog injectors if so equipped.<br />The fuel should be useable up to 6 months with very little problem, but after that, all bets are off.<br />So your fuel is just fine.
Deenniiss
Re: Old Gas
Its a 1994 Plymouth Voyager Van (4 cylinder) Im not much into car info but it sounds like I better not use up the gas in my car.
RICKRICK1
Ensign
Re: Old Gas
Use it in your lawn mower :p Just joking at this time of year you are not mowing your lawn I'm sure, how about snowblower. Add stablizer to it and it should be ok.
OBJ
Re: Old Gas
My dad dumped some 50:1 mix in the old 77' ford van we used for pulling boats around the yard. It was like a smoke screen every time we cranked the old girl up.<br /><br />OBJim :D
wakataka
Re: Old Gas
Maybe I was just lucky, but I ran about 7 gallons of 2 year old 50/1 through my 1987 fuel injected Ford pickup with no apparent ill effects. I think the trick is to dilute it with enough fresh gas so that you end up with a decent mix. I put it through in two batches, each mixed with a full tank of fresh 89 octane.<br /><br />But I agree, the lawnmower is a lot cheaper to replace than even an old car.
totalivewire
Re: Old Gas
being a better car mechanic than boat mechanic, Ive gotta say that would be a big mistake if you run boat motor gas in a car.even if you cant tell right away if it has a bad effect, time will take its course and soon it could effect your whole fuel system.1 word sums this up, kurputt :eek: <br />be smart and dont gamble
D
DJ
Guest
Re: Old Gas
Dennis,<br /><br />Do not put it in your car/truck. The symptoms may not show up right away.<br /><br />The most likely components that will be damaged are cat. convertors and oxygen sensors. <br /><br />That is precisely the reason, and some others, that outboard manufacturers (2-stroke) are a having a tough time adapting cat. convertors to marine use.
