Old Johnson 35
imp63
A guy offered to sell me an old Johnson 35hp motor. He says it runs but needs a tune up. I'll include a picture here. Hopefully someone will be able to tell me more about it and what I should be willing to pay.
F_R
Re: Old Johnson 35
It is a 1958 model. Can't tell from the picture if it is electric start or not. They are good reliable motors if in good condition. If it is a junker, it is a junker. No way to tell from this distance.
tashasdaddy
Re: Old Johnson 35
the main problem with that vintage, is the lower unit. the clutch dog, and forward gears get worn, and it will not stay in gear. i know this from experience with one. you need to take it for a ride, and see if it stays in gear.
if lower unit, and compression are good. you can have it running like new for $200-250.
freddyray21
Re: Old Johnson 35
lower units are plentiful though for those. Those are good motor, but like TD said about 2-250 to get it fully right. New seals ect. That motor around here in good running condition about 400 dollars.
imp63
Re: Old Johnson 35
The guy told me the other day he would sell it all to me, boat, motor, and trailer for $500. It is electric start with electric choke. He didn't say anything about it not staying in gear. Most of the lakes are frozen up here this time of year, so to get it out on the water in next to impossible. Are there any covers I can take off to check it out?
jay_merrill
Re: Old Johnson 35
If the boat and trailer are sound, $500 doesn't seem unreasonable to me. You'll probably spend money on all three, but the beauty of an older boat is that you usually don't have to do it all at once.
That motor is also easily converted to a single line/fuel pump setup, so you won't have to fool with pressure tanks if you don't want to. I don't disagree with the refurbishing numbers posted here in general, but my own preference would be to budget about $500. To some degree, the eventual amount depends on how much of the work you will do yourself. For example, I don't like to reseal gearcases on the very old motors, just because getting some of the parts out can be tough. Call me a chicken, but I'd rather let my local OMC/BRP shop do the work, rather than to risk breaking something. The guy that owns the shop that I patronize, has done hundreds of them and likes to fool with the older motors, so he does mine for $100.
Its good that the motor is a 1958, too. Although I can't confirm this, I have been told by the guy that I just mentioned, that the '57 and older gearcases used a different clutch dog, which is now an NLA part. If the dog in this one happens to have problems, you should be able to get a replacement. Also, if the clutch dog mating surfaces on the gears are worn, you may be able to get them "cut." As long as this has not been done to them before, doing so will save you replacement costs.
All of this said, I ran a pair of 1958 ERude 35s (same motor) for hundreds of hours on two different boats. When refurbished properly, they are very reliable. They do burn more fuel than the newer motors, but considering the cost of buying them & refurbishing them, you are still way ahead of the game.
F_R
Re: Old Johnson 35
That particular model is fairly popular among collectors/restorers because of its' good looks and ease of repairs.
