Old Johnson Question - QD16 10hp
fishchaser
Call me crazy, but I got a good deal on a 1955 Johnson, QD16, 10hp Seahorse. I'm trying to get it running for my little flatbottom.
I'm working thru some carbuerator issues right now, but I've realized that I don't know where to set the throttle when trying to start the motor.
Throttle is on the tiller handle, but there are no markings anywhere. Probably came off years ago. Can anyone tell me the proper throttle position for starting this thing? Left, Right, Middle? Thanks.
CATransplant
Re: Old Johnson Question - QD16 10hp
Start about halfway. Try that. If it takes several pulls, go a little farther. When you find the combination, mark the twistgrip and the tiller handle to help you from then on.
The one thing I've found is that each engine has its own sweet spot throttle setting for cold starts. Warm starts are easy.
Your QD16 should start cold in two pulls...three max. You'll find the right spot.
samo_ott
My QD19 ('58) starts first pull every time cold. But of course the start mark is on it. You can buy then marked rings for the twist grip remanufactured... But eventually you will find and it just mark it as mentioned.
F_R
The markings are notoriously inaccurate. No matter what the markings say, or don't say, the proper start position is put the shift in neutral, then advance the throttle as far as it goes. It will only go to the proper start position. This assumes, of course that the shifter interlock isn't worn out. If it is, fix it.
fishchaser
Thank you for the quick responses. Gonna give this a try as soon as possible.
wbeaton
Also check your coils for cracks. If they are original they will need to be replaced.
fishchaser
WBEATON, your timing is dead on.
Took the pull starter off tonight and found that both coils are cracked. Guess I'm gonna need a couple more parts.
Wonder where this will end?
CATransplant
If you replace those coils and the points, it will end with a nice running 10 hp outboard that should outlive you if it's maintained properly.
Don't give up yet.
wbeaton
Yes, don't give up. It will be a great motor. The QD's are excellent.
You can't set the carb until after you've replaced those coils.
fishchaser
Thanks for all the info and encouragement.
Went down to my local Johnson dealer today. Picked up a carb kit, new water pump impeller, and plugs. Had to order the coil and points. That was a quick $140. But should be well worth it.
Can't wait to hear this baby run.
