MD Coleman
- Nov 5, 2018
- 2
I inherited a boat from my father and it has an old Lowrance x22a in the dash. Issue these things were factory installed in a lot of boats (Lawrence must have had a great deal going then) but anyway, the transducer is thru hull and keeps good bottom at speeds but head unit is shot. I need to know what other older head units or newer would hook up to those cables already installed. Or if they have an adapter that I could use to hook up newer units from Lowrance or older. If an older unit with work what would some of you guys that had experience back in the late 90's recommend I look for. Boat is 1997 so I say this was put in around 96-97. Have no clue what the thru hull transducer is because you can't get to it. Thank a bunch folks. MOD EDITED
