Hi,
Im having problems with an old mercury 20hp merc200. I think its somewhere in the 67-72 range and I'm looking for information on this motor.
The motor starts easy and runs smooth but it is a little choppy at a low idle. On new plugs it will run a decent top end and sounds alright, but after about 10 or 15 minutes of high end and speed and throttling down, the motor will not return to full throttle. It seems to bog down at about 1/4 throttle and will not return. If I pull the plugs and check them they are usually black and filled with sludge.
What could be causing this? My local merc dealer had me put in gapless plugs and I think that's when I started having problems. Can someone confirm for me which plugs I need to put in this motor, or point me in the direction on what might be going wrong?
Thanks
Thanks
