old merc water pump
MH7142
i have old merc 400 thunder bolt 1960-61 i was wondering if anybody could tell me how to tell if water pump is working i put a 55 gallon drumfilled it with water i run motor for about 5 minutes and it didnt get hot when i give it throttle it started bubbling where does water come out the guy i bought it from said pump was bad how can i tell
JB
Re: old merc water pump
Moving to Mercs
Darryl34
If it's anything like the 70's style,the water comes out with the exhaust through the prop.Their should also be a hole in the lower cowl rear right side with water comeing out from the head for cooling.If you've got ear moffs,use them,then you will be able to tell a little better how much circulation you are getting.
Chinewalker
In the belly pan (lower cowling) on the port side of the motor, near where the cowling meets the exhaust housing (mid-section) there should be a pin-hole water relief outlet. Get a piece of wire and clean that out.<br /><br />That motor will also spritz a mist out the exhaust relief nub on the rear of the exhaust housing.<br /><br />95% of the water goes out the exhaust in the lower unit, under the anti-ventilation plate.<br /><br />If you're unsure about anything cooling related, put in a new impeller - they're cheap insurance. Might have to go to oldmercs.com to find a manual for yours.<br /><br />- Scott
Virago85
I have a 77 175 and mine will not put water out of the pee hole unless I am under throttle call mer and the said that is normall for the biger mercs it runs about 130 thru no wake and about 100 under throtle
