Old mercontrol unit works backwards, am i missing something ?
Status
Not open for further replies.
Bikevouwer
Haven't post much here, but i am really puzzled now, my son has an old placomm poly boat 2 seater, due to regulations he is only allowed a 10Hp outboard, to be on the save side (fines are ridiculous here) i gave him a 7.5Hp mercury 2 cilinder 2-stroke, came together with an old mercontrol remote control, when i try to hook everything up i came to find the shifting works backwards, pushing the lever forwards puts the engine in reverse, pulling the lever to the back of the boat gets it in forward gear, have looked trough the engine side and everything is 1000%, its in de control box for sure.
Did some measurements and found out that full throttle can be achieved on both gears forward and reverse.
Placing the lever on the other side gives the same output, i am beginning to think i got the wrong control box for this engine.
need some input from the specialist overhere.
Thanks John
sutor623
Re: Old mercontrol unit works backwards, am i missing something ?
Yea I bet that the controls and motor are backwards in operation. You hear about this sometimes. I guess you could use it how it is until you fin the proper box.
Bikevouwer
The light just came on ! put the controlbox upside down and it works like its supposed to work ! duh
gm280
Are you absolutely sure you don't have the shifter and throttle cables reversed at the engine? That would explain everything perfectly...
matt167
Some of the Mercury 15hp and lower control boxes were reverse control from the factory in the 60's-70's. It's probably the right box for the 7.5hp, but you can just change the cams to swap it to forward control. Some old dealer is bound to have an old set of cams on the shelf for it.
Bikevouwer
I think you are right ! i am a 48 year old tech man with 32 years of experience in engines and trains (yes the really big ones) and couldnt figure this one out.
Status
