OLD MINN KOTA 565 turbo HELP
Hello
just bought an old minn kota 565 turbo bow mount 36 lbs thrust for 25 bucks w/batt. Prop works fine from foot pedal. But when i step on pedal motor does not turn. I opened it up to see that one cable is hooked up loosely, and other is completely broken off. I hope this is an easy fix!!!!! I am pretty sure it will work but I have no clue how to fix it...Can someone please explain it to me. Also it seems to be missing the lower item that holds the cable at the single pulley, and last the mon/con switch wires are all taped together, could that be just a bad switch? PLEASE HELP!!!!!
Steve
