Old Name
Sparke
I would like to rename my boat and I need to get the old paint off. Would I go with a orbital sander and wet sand? I did a search and I didnt see any posts. Thanks for the help.
Bob_VT
Re: Old Name
What kind of hull? Fiberglass? Wood? Plastic? Steel? Aluminum?
Most people try acetone to remove old paint lettering
Sparke
Re: Old Name
I will try that first, much easier then sanding.
Sparke
Re: Old Name
I know my wife said the same thing, she said it's bad luck to rename your boat.
MichaelP
Re: Old Name
Before you rename your boat read and follow these instructions very closly. Ceremony for Renaming Your Boat Everyone knows that renaming your boat will bring nothing but bad luck and make your boating experience something that you will want to forget. But what happens when, after months of searching, you find your dreamboat with a name that you just cannot live with. Renaming a boat is, of course, not something to be done lightly. Since the beginning of time, sailors have sworn that there are unlucky ships and the unluckiest ships of all are those who have defied the gods and changed their names. So, is there a way to change a name and not incur the wrath of those deities that rule the elements? Yes, Virginia, there is. According to legend, each and every vessel is recorded by name in the Ledger of the Deep and is known personally to Poseidon, or Neptune, the god of the sea. It is logical therefore, if we wish to change the name of our boat, the first thing we must do is to purge its name from the Ledger of the Deep and from Poseidon's memory. This is an involved process beginning with the removal or obliteration of every trace of the boat's current identity. This is essential and must be done thoroughly. I once went through the ceremony after the owner had assured me that every reference to his boat's old name had been purged from her. A couple of weeks later, he discovered he had missed a faded name on her floating key chain. I advised him to start over, perhaps with a little extra libation for the ruler of the sea. Unfortunately, he declined. Since then, his boat has been struck by lightning, had its engine ruined by the ingress of the sea, been damaged by collision and finally sunk! It pays to be thorough. In purging your boat, it is acceptable to use White-Out or some similar obliterating fluid to expunge the boat's name from log books, engine and maintenance records etc., but it is much easier to simply remove the offending document from the boat and start afresh. Don't forget the life rings and especially the transom and forward name boards. Do not under any circumstances carry aboard any item bearing your boat's new name until the purging and renaming ceremonies have been completed! Once you are certain every reference to her old name has been removed from her, all that is left to do is to prepare a metal tag with the old name written on it in water-soluble ink. You will also need a bottle of reasonably good Champagne. Plain old sparkling wine will not cut it. Since this is an auspicious occasion, it is a good time to invite your friends to witness and to party. Begin by invoking the name of the ruler of the deep as follows: Oh mighty and great ruler of the seas and oceans, to whom all ships and we who venture upon your vast domain are required to pay homage, implore you in your graciousness to expunge for all time from your records and recollection the name (here insert the old name of your vessel) which has ceased to be an entity in your kingdom. As proof thereof, we submit this ingot bearing her name to be corrupted through your powers and forever be purged from the sea. (At this point, the prepared metal tag is dropped from the bow of the boat into the sea.) In grateful acknowledgment of your munificence and dispensation, we offer these libations to your majesty and your court. (Pour at least half of the bottle of Champagne into the sea from East to West. The remainder may be passed among your guests.) It is usual for the renaming ceremony to be conducted immediately following the purging ceremony, although it may be done at any time after the purging ceremony. For this portion of the proceedings, you will need more Champagne, Much more because you have a few more gods to appease. Begin the renaming by again calling Poseidon as follows: Oh mighty and great ruler of the seas and oceans, to whom all ships and we who venture upon your vast domain are required to pay homage, implore you in your graciousness to take unto your records and recollection this worthy vessel hereafter and for all time known as (Here insert the new name you have chosen), guarding her with your mighty arm and trident and ensuring her of safe and rapid passage throughout her journeys within your realm. In appreciation of your munificence, dispensation and in honor of your greatness, we offer these libations to your majesty and your court. (At this point, one bottle of Champagne, less one glass for the master and one glass for the mate are poured into the sea from West to East.) The next step in the renaming ceremony is to appease the gods of the winds. This will assure you of fair winds and smooth seas. Because the four winds are brothers, it is permissible to invoke them all at the same time, however, during the ceremony; you must address each by name. Begin in this manner: Oh mighty rulers of the winds, through whose power our frail vessels traverse the wild and faceless deep, we implore you to grant this worthy vessel (Insert your boat's new name) the benefits and pleasures of your bounty, ensuring us of your gentle ministration according to our needs. (Facing north, pour a generous libation of Champagne into a Champagne flute and fling to the North as you intone Great Boreas, exalted ruler of the North Wind, grant us permission to use your mighty powers in the pursuit of our lawful endeavors, ever sparing us the overwhelming scourge of your frigid breath. (Facing west, pour the same amount of Champagne and fling to the West while intoning † Great Zephyrus, exalted ruler of the West Wind, grant us permission to use your mighty powers in the pursuit of our lawful endeavors, ever sparing us the overwhelming scourge of your wild breath. (Facing east, repeat and fling to the East.) Great Eurus, exalted ruler of the East Wind, grant us permission to use your mighty powers in the pursuit of our lawful endeavors, ever sparing us the overwhelming scourge of your mighty breath. (Facing south, repeat, flinging to the South.) Great Notus, exalted ruler of the South Wind, grant us permission to use your mighty powers in the pursuit of our lawful endeavors, ever sparing us the overwhelming scourge of your scalding breath. Of course, any champagne remaining will be the beginnings of a suitable celebration in honor of the occasion. Once the ceremony has been completed, you may bring aboard any and all items bearing the new name of your vessel. If you must schedule the painting of the new name on the transom before the ceremony, be sure the name is not revealed before the ceremony is finished. It may be covered with bunting or some other suitable material.
__________________
Of those who receive good advice, only the wise will profit from it.
MichaelP
Re: Old Name
That was something I think I found here on one of the forums. I'd like to give credit to whoever contributed/wrote it but don't know who that is. Also I can't find it again luckily I copied it. Of the many things I don't know I do know that it would be nice to have it added to one of the boat topic stickys.
Cadwelder
Re: Old Name
UMMMMM strong the dark side, it is .....be mindful of your thoughts before renaming. Only the wisest of the wise should try such things.....veeeerrry careful you must be...
Sparke
Re: Old Name
Thank you very much for the great info. I will not talk this lightly and I will not change anything in my profile untill the ritual is done and complete. I will start with the champaign then I might have to move to beer since I live here in the state with 10,000 lakes and our beer is brewed from these lakes. I would assume that the northen water gods would appretiate this gesture of thanks and grant me forgivness.
Yacht Dr.
Re: Old Name
Hello Sparke and welcome to Iboats :) ..
First off.. just drink some wine or something..and pee on the bow ( that saves from breaking the bottle and wasting precious spirits ;) ) .
Ok now.. to remove the name..its painted on ?? Not stickies ?
Got pics ?
Sometimes with paint a nice fresh razor blade can chip that off..then light wetsanding and a buff .. sometimes..
YD.
Sparke
Re: Old Name
It is still in storage I was hoping to get it out this weekend and start with repairs and upgrades. This thing has been a bit of a project boat I wish I would have taken before and after pics but that's all hindsight now. I will post some pics when I do get her out.
The name was painted on and it is badly faded and really rather ugly. I have gotten some good advice here so I will try the easy ones first and then go from there.
Psiclown
Re: Old Name
I should have researched this name changing ceremony years ago. I changed the name of my old jet boat, and it caught on fire......TWICE. :eek:
