Old Quicksilver 2 lever control box - need more info. 1967 ??
Welcome aboard
how about posting a pic
what information are you looking for?
are you talking the single lever throttle/gear select with separate fast-idle, or are you talking the much much older 2-lever with separate throttle and gear controls/
Mattgaw122
Looking mostly for the wiring for it. I would also love to know the year and model. Where di you think the model # is located?
that control box is from the mid 50's
unbolt it from the boat, look inside the cover
Mattgaw122
Thanks, should I keep it installed? Or should I switch it to a single lever merc control box I also have.
that is up to you. they both do the same thing. pull on cables going to the motor. I like the old dual control units myself.
