- Mar 8, 2009
- 42,892
Have a very old Reddy Heater M100D. Been working great for all these years (about 25) until today. The motor would just hum, so I flipped the fan by hand and it started and heated up my area.
Later took the motor apart and found the front bearing was dragging. The short of it, the front bearing is cracked and appears the motor is not made anymore. Motor M30718-01 or M50450-01 no longer available and no replacement.
Specs for motor 1/6 HP, 3400 rpm, 120VAC and uses a relay for start then switch to run
Wondering if I could use a newer model motor 102001-30 or 33, uses start capacitor
The motor specs out about the same only issue is if my pump and filter box would fit
