Tigosaurus
- Aug 24, 2016
- 9
Hello everybody! I'm sure glad I've found this forum. I've been working on a skiff that is in need of repair. I've replaced the benches so far, but the transom is more of a challenge. The boat was probably built in the 1970s and I'm not sure if the transom board has been replaced since it was manufactured. The rotten board was only 8 inches in height. Unfortunately, I didn't take a picture of it before I removed the rotten one..
Also, you can see the overlaps of the aluminum between the hull and transom, which is curved inward below the gunwale, creating a need to widen the hull while I insert the new transom. I have removed some rivets. The questions I have:
Do I need to remove the entire transom aluminum by taking off all the rivets, or just enough to remove enough rivets to pull the hull out enough to insert the transom?
Or will lining the gap with 5200 at the point I stopped taking out the old rivets, then simply replacing with new aluminum rivets do a leak proof job?
Should I replace with the 8" deep board, or go with a 12"?
