restornator
- Aug 15, 2009
- 361
I have replaced the armature assy. for a 58 18hp Johnson, with one from a 54-55 10hp. i assume this is a 100% interchangeable part. Anyway, while starting with a pull rope, the armature assy moves with the flywheel, to the stop position. It doesn't stay in the start position unless i hold the throttle handle.
Is there an adjustment i can make to increase friction on the armature seat? (the part that swivels) or is there an adjustment on the throttle handle?
i should also note that the throttle gears (where the handle pivots up and down) are missing a few teeth
