old wiring in fish and ski
jsimms724
gentlemen I have 1998 starcraft fih n ski , it is prewiwired for a trolling motor but it has never been used dont know the gauge of the wires and I cant send a pic (boat at lake ) the setup looks a litle cheap . the setup passed a continuity check. (this a twelve volt setup)I am going to rewire this winter over this concern, what gauge wire should I use to be safe and last 4ever? after fishing wires thru hull it will be about 18ft of wiring. I will also replace the circuit breaker in the panel where the plug is . it also looks cheap, any tips or any thing I should know thanks in advance.
Re: old wiring in fish and ski
Ayuh,.... You wanta replace perfectly good wirin', but don't tell Us what yer gonna run off it,..??...
Trollin' motors are not all equal...
jsimms724
http://www.walmart.com/ip/Watersnake-Shadow-FWDR54-48-Trolling-Motor/13228525 the wires just seem cheap I thought they wuold be more substantial just dont want any problem next spring the battery i will be using will be just for the trolling motor And charged by a smart charger not the boat motor
jsimms724
54lbs thrust 12 volt 48 amp max draw thanks bond -o
Silvertip
The circuit breaker belongs within a foot of the positive termnal on the battery -- not at the bow by the connector. just because something looks cheap does not mean it is not safe or functional. Why replace existing wiring with new wiring that may look the same. Over that distance and with that motor, 6 gauge wire is ideal, but you may get away with 8 gauge. The distance is not 18 feet -- it is 36 feet as you need to consider round trip. The breaker will need to be a 60 amp manual reset. 50 amp is too close to the maximum current draw.
jsimms724
thank you sir, that is exactly what I needed to know
