Older 1981 Flywheel Bellhousing -Can I upgrade to newer Alpha One style?
daviru
Hello,
So I had to replace gimbal / transom plates, exhaust y pipes, manifolds, steering to newer 1983 type Alpha One.. Thought I was all set to go as I was dropping in the 1981 305 GM engine I realized the rear engine mount holes on the flywheel housing are much further apart than the holes in the transom plate. I am assuming that I can just replace the flywheel cover (#865657). I would think there is no need to change the flywheel. Am I correct?
You helped me out with my original concern with changing out the manifolds a few months ago (routing hoses/thermostat housing etc.).
Ayuh,..... Welcome Aboard,...... Flywheel cover, Yes,.... Flywheel, No,.... Coupler, Maybe,.....
daviru
Thank you for your quick response. Ordered newer flywheel cover and keeping fingers crossed that coupler will work -since I just replaced it last season.
