Polara Pat
- Jul 2, 2013
- 53
This is a bit of a two parter, I hope that's ok. First off I've been having problems nailing down the actual year of this motor since the serial # doesn't seem to come up on any of the charts. It is a Canadian built motor, so maybe that's the issue. The serial number is 7014680 and it is very clear. Alright, so my issue is that I'm not getting fuel delivery to the carbs. I can pull the inlet line off at the pump and get a strong shot of fuel with the priming ball but there is no fuel on the outlet port. Does this sound like a bad pump? I was under the impression that I should be able to get pressure through the pump to the needle and seats. Correct?
