Hi,
I have an older DF25, (I think early 80's). Runs but idles like a bear and I hope to be able to get it so do better. There is a jet you can remove from the outside top of the Carb and it looks as though it should have a tiny hole going all the way through, (from top to bottom), but it does not. I was thinking it may be clogged and this is the source of the rough idle. Anyone familiar with this jet who may know if it has a hole going from top to bottom?
Photo of Jet attached.
Thank You
Thank You
