I am considering converting a older "water Winnebago" ('87 27ft Bayliner Buccaneer Sail, OB powered) into a "poor man?s motor sailor". The stern is relatively vertical and with minor modifications will lend itself to an small I/O installation.
I do not intend to plane at all, but would like to get hull speed just off idle and the extra available reverse thrust would be real handy for a 6000 lb boat in tight marina situations.
It currently has a 12hp outboard and it takes a while to stop it. I also am tired of listening to a screaming OB to achieve hull speed. In addition, an over powered semi plane might be handy for getting out of bad weathers way too sometime.
Just seems like a win/win idea. The boat is fully depreciated but in good working condition. It cost me more to fabricate its triple axle trailer than it did to buy the boat.
Money (in marine terms) is essentially non-existent, but I'm real handy and am looking for a Mercruiser 120, or the 224 ci ford based system, or whatever to install. I can refresh or rebuild any engine as long as the block, head and crank are good... after that, it gets expensive.
Since this may entail buying the engine and I/O units separately, I need to know what went or can go with what.
Can anyone shed light on the 70s and 80s 4 cyl Mercruiser and their out-drives? Thanks.
Dave
Dave
