Re: OMC 1.6 outboard motor
tk101,<br /><br />I believe your 1.6 is an OMC Sea Drive. Is it on a set back bracket that is attached to a full transom? If so, that's what it is.<br /><br />The 1.6 is a V-4 engine of around 115 hp. It is basically the same as the true outboard version except for the cowl and mounting system.<br /><br />The Engine was built by OMC, makers of Johnson and Evinrude. OMC is now defunct as of late 2000. The Johnson and Evinrude lines were picked up by Bombardier Corp.<br /><br />Don't let that scare you, parts for these engines are available.
