omc 1.6 seadrive unit
sidingguy
I have a Starcraft 191v Islander with a 1.6 0mc[110 hp].I would like a little more power. Found a 130 hp Evinrude with a 25" shaft.Does anyone know if this conversion can be made?
Check on parts lists to see if pivot brackets are the same between the 2 models.
sidingguy
Different part numbers,maybe build an adapter plate to bolt up to sea drive bracket?
