Omc 140 3.0l convert from points to electric?
You can either get a pertronix trigger, or a delco voyager distributor.
However, i would simply keep the points.
Lou C
if you convert to electronic from points you will have to either install a ESA module that works with the electronic distributor, or fab up the diode fix used for the Petronix system. I thought of doing this but in the end it was just easier to keep the points and replace them when needed. I've usually gotten 4-5 seasons out of a set of points and condenser. On the OMC with dog clutch shifting the ESA must work or else you will have trouble shifting out of gear. When its all set up right it actually works well, it will not stall the engine as can happen with a Merc Alpha.
