OMC 140 Alternator replacement/conversion
ryan_eyres
Hi all,
I've got a 1978 OMC 140 with stringer outdrive that I've just finished rebuilding and re-installing. The alternator is old and in bad shape so I am replacing it to make everything nice and new.
The current alternator looks like this one here: http://www.marineengine.com/newparts/part_details.php?pnum=ARC40152&ptype=&Engine=&Model=
and it has an external regulator I believe that is bolted to a plate underneath the manifold.
My question is: what alternator should I be replacing this unit with? I was thinking of doing away with the external alternator and replacing it with a more modern, internally regulated alternator. I believe this can be done with some simple wiring modifications. Am I right? If so, does anyone have part numbers or model numbers for some alternators that would work for my application with this style mounting bracket?
Thanks in advance,
-Ryan
Bt Doctur
Re: OMC 140 Alternator replacement/conversion
ARCO ARC 40152 ,internal reg.,12V- 61A
ryan_eyres
What is involved in converting the wiring from my externally regulated alternator to this one?
Thanks,
-Ryan
Bt Doctur
cut and tape the old wires. install the heavy orange wire to the new alt. and maybe a heavy black wire. thats it
ryan_eyres
Any other more part numbers out there for a more commonly found alternator? I'm trying to source it locally..
Thanks in advance,
-Ryan
