OMC 1978 305 choke coil
GRANBATEAU
Hello:
I have a 1978 OMC stern drive 305 ci engine. I need the choke coil, cover, and rod that goes from the coil to the carb. This coil is one that bolts directly onto the intake manifold. The manifold is a Holley and the carb is a Rochester Quadra jet model 17057290. Can anyone tell me where to get these items?
Thanks and any help will be greatly appreciated.
Napa. Standard GM small block divorced choke
Lou C
That, or a website called quadrajetparts dot com they have nearly everything you could need, even if none of that shows up in the OMC on line catalogs.
