dlogvine
Master Chief Petty Officer
- May 4, 2015
- 839
I just got this new old boat, 1984 Mercedes (I believe it is now freedom marine boats) with 3.8L OMC engine. There is a pair of Serial numbers and model numbers on the drive Mod No 382STMRCOM, Ser No J 836439 and the second pair is Mod No 983487, Ser No J 3575..( the last two digits I need to look up again since on the picture I made the label is slightly folded. Pictures are attached. I did not have a chance to start it since the ignition lock does not have a key and I did not really want to hot wire it. So Im waiting for the new ignition lock to arrive. But I looked at the engine and it looks very dirty to me, carburator even without taking it apart is gunky, there is old oil - almost black on the dip stick. And the boat has not been used at least since '13.
Now Ive got a couple questions:
How should I clean up the fuel tank, fuel lines before trying to start this baby.
What carburator kit should I use for this carb, looks like it is a Rochester 2 barrel carb (photo is attached).
Im also getting a manual for this drive, just waiting for the shipment to arrive.
Any advice is more than welcome.
Also one more question of the topic, the trailer has a surge brake actuator, looks like an older Dico Model 6. When I opened the master cylinder cap - there was just a red rusty mess inside or the reservoir, not much brake fluid, just some goo. How should I clean this? master cylinder reservoir and brake lines.
Thank you.
Thank you.
