Re: OMC 2.3 ESA switches
Cut meaning none. <br />The switches control the function of the ESA module and the ESA module cuts the spark on 1/2 the cylinders.<br />So faulty switches could cause erratic or no spark indirectly. Easy to check, just unplug the ESA module. Your ignition should work as if the ESA setup wasn't there.
