OMC 3.0 COBRA STERNDRIVE
TUGSGF
JUST AQUIRED AN OMC 3.0 COBRA STERNDRIVE ALL COMPLETE AND GOOD CONDITION. JUST TRYING TO FIND OUT A LITTLE INFO ON THE ENGINE AND WHERE TO GET A WORKSHOP MANUAL. INFO I HAVE IS AS PRINTED ON THE ENGINE<br />MODEL No SERIAL No<br />302AMRGDP T1029657<br /><br />MOD No SER No<br />985268 T0545667<br /><br />IT IS GOING INTO A BARE BOAT IS THERE ANY GOLDEN RULES OF HOW FAR FROM THE WATER LINE SHOULD THE DRIVE SIT?<br />ANY HELP WOULD BE APPRECIATED
Re: OMC 3.0 COBRA STERNDRIVE
Yes.......<br />The Anti-Ventilation Plate should be Even with, or Just Above the Bottom of the transom...........
TUGSGF
EXCUSE MY IGNORANCE, BUT WHEN YOU SAY THE LEVEL OR JUST BELOW THE TRANSOM ARE YOU TALKING ABOUT THE DEEPEST PART OF THE TRANSOM AS IN THE BOTTOM OF THE BOAT?
Don S
What you need is a template for making the cutout on the transom. The cutout gives the X dimension which is the the center line of the engine crankshaft in order for the drive to end up with the anti-ventilation plate approximatly flush with the keel of the boat. Cutting it too high or low will cause problems.<br />Since you have the Cobra drive, and they are no longer available, but if you find a local Volvo penta dealer and have them order the paper template for the SX drive transom shield cutout. It's the same as the OMC and will work perfectly. I will see if I can't find the paper template part number.<br /><br />Just an FYI...Typeing in all caps is considered yelling on forums and it's hard to read. I know you're not yelling, so please turn off the caps lock.
TUGSGF
Thanks Don.<br />sorry about the caps, didn't know,<br />if you could find part number then it would very much be appreciated.
Don S
The Volvo Penta template number is 3850029.<br />Volvo also has a transom drilling fixture PN 3851081-4 that when put on the transom properly and lined up using the proper methods (not on the template) will get you holes at the proper angle and the cutout in the right place.<br />Just remember one thing. Once you make the cut and drill the holes, you either live with it or rebuild the transom.<br />I don't have any problems cutting them, but I learned before I started cutting.<br />I would seriously consider talking to your local Volvo dealer before you take a saw to your transom.
TUGSGF
Thanks very much. appreciate the advise no doubt some more problems will arise as i progress.
